Recently bought a 95 G20T with issues
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
InitialDerek
Car: 93 Nissan 240SX Conv.
Hello,
I'm a Newbie, I recently bought a 95 G20T & it needs a few things:
Motor mounts, left axle, & new exhaust
Generally speaking are these repairs very expensive?
Also my door remote was missing, is it expensive to reprogram another one?
Thanks Guys,
TurboChargedSE-R
Car: 1993 Nissan SE-R with a BIG turbo
1993 Nissan 240SX convertible KA24DE-T
Motor mounts are easy: you can buy new OEM ones through dealerships like http://www.mossyperformance.com and http://www.courtesyparts.comOr, you can buy aftermarket insert from Energy Suspension and Prothane. Either way, expect to spend the better part of an afternoon replacing the mounts. Maybe longer. It can be a tough job (read: long) for the inexperienced.
Axle: Buy a remanufactured one from AutoZone, PepBoys, etc. Easy install if you have the right tools, maybe 1/2 an hour to 1 hour.
Remote: I have no clue. Sorry.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Unfortunately energy suspension inserts don't work on the G20. So either buy new oem, aftermarket or fill the mounts yourself. I believe if you can find a remote, the programming is pretty simple. Should be able to get you the process from a friend who programmed his remote.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
