autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Thu Jan 16, 2003 5:35 pm
The larger the gap, the more spark is exposed to the air/fuel mixture. A larger spark plug gap increases the efficiency of the burn in the combustion chamber. If your ignition coil doesn't provide enough voltage, increasing the gap on your spark plugs will result in fouling and misfiring. I remember in the early eighties we use to change the plugs at the 15,000 and 30,000-mile interval and have a customers concern of decreased fuel mileage since the plug change. The result is when the gap is slightly wider, which on a slightly worn plug the gap will be wider, you will have an increase in the spark and gas mileage will increase but only on an average of one to three MPG. But with today’s fuel prices, a lot of our Infiniti customers are looking at the concern of the miles per gallon, and on the other side of that, we have customers that could care less about the mileage, they want performance.I would suggest keeping that gap within the specifications, and if I remember correctly, it is .038 to .042, depending on the vehicle.As far as the tips being whitish in color, you could have many things that come into play causing a slight lean condition, I would first make sure you have the correct plug heat range, and go from there.A small vacuum leak, restricted fuel spray from the injectors, ignition timing. A good scan on the engine with consult or other generic scan tool can monitor the sensors and give you an idea in those areas.
