Thanks for the help. But doesn't it make sense that if the MAF is GOOD, unplugging it and revving it will result in poor performance?jaytv1019 wrote:Your maf is bad.
Never ever clean your maf with brake cleaner! I always thought that is how to clean it but I ruined mine, and everyone else who has done the same ruined theirs.
Unfortunately you need a new one. To test, unplug the maf and start the car. If the maf is bad, the car will start and idle smooth but a little higher (maybe around ~1100 ish) but will not rev past 3500 - 4000 very well. Test it and let us all know.
If you end up needing one I can help, I think I have a couple laying around here from swaps.
Later,
I just checked my MAF. I unplugged it and started it. The idle was smooth and revving was a disaster. When I **** the car off and plugged it back in, the it would not allow me to rev past 2500. I then disconnected the battery for two hours to reset the ECU, but now it is even worse, not holding idle. It starts up and fluctuates between 100 and 700, but when I clutch out, the car just dies.jaytv1019 wrote:Your maf is bad.
Later,
First, check your ECU to see if it's throwing any codes.donnie89240sx wrote:well this is my problem i think its my mafs but not sure. wont idle worth a crud but if i rev it up or while im driving it runs fine. burns rich but runs. wont run good under 2000 rpms. every now and then can get it to idle but runs really bad and idle jumps around. i need to find out if it is the mafs before i go and spend 269 on one and that not be the problem.
You should check the forums then... No need to spend that much on a KA-E MAF.donnie89240sx wrote:well i cant find any mafs on ebay. and i can not find any in any junk yards around here for under 100 dollars. if i am going to spend that much on one in a junk yard. then imma just put in the rest and get it brand new so it was a warrenty and garentee it will work. my ecu isnt throwing any codes. i recently did a check with another ecu from a junk yard and it wanted to run better but it missed on one cylinder.
