Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles listed above is 0.946
liter (1 qt.) in 3,200 km (2,000 mi) for the 1st 80,467 km (50,000 mi). For vehicles with
more then 80,467 km (50,000 mi) the acceptable oil consumption for engines is 0.946 liter
(1 qt.) in 1,207 km (750 mi). CAUTION: This above rate only applies to personal use vehicles, under warranty,
that are driven in a non-aggressive manner and maintained in
accordance with the appropriate maintenance schedule,
CAUTION: This rate does not apply to vehicles that are driven in an aggressive
manner, at high RPM, high speeds, or in a loaded condition (for trucks).
See ‘Causes for Oil Consumption’ below. Oil consumption for vehicles
driven under these conditions will be higher and may include Fleet and
Commercial customers.
Wow, by that metric, my almost 280k Honda passes their criteria for oil consumption. Good to know!!lne937s wrote:Oil Consumption
I think you got the wrong impression from what I wrote. Of course Nissan's use Nissan engines and I have seen no evidence of oil consumption... I said as much in my previous post. However, rental car companies rent more than just Nissans. And many of those other cars are known to consume oil, so there is a significant chance that the rental car companies will have significant issues with those cars.Bubba1 wrote: As far as oil consumption goes, last time I looked, Chrysler does not supply Nissan their engines. I have not looked at the 2013-14 Nissan service manuals, but I do not believe the 2.5L motor Nissan uses in the Altima is designed to consume as much oil in 2000 miles as what Chrysler says is normal for their engines.
Passes? PAH! My 285k mile Maxima didn't consume a single DROP of oil. Geez. VG30>modern Nissan.PapaSmurf2k3 wrote:Wow, by that metric, my almost 280k Honda passes their criteria for oil consumption. Good to know!!
That quote is about new Chrysler engines, NOT the QR25DE. The QR has no reported problems with burning oil. I only put that quote from a Chrysler service bulletin in there to give an example of many new cars that are NOT Nissans but often show up in rental car fleets (like the Chevy Cruze, Dodge Dart, etc.) do have a tendency to burn a lot much more oil than cars from a decade ago and could be very problematic if not checked. It is a comment about rental cars in general that may not be getting proper maintenance, not Nissans.MinisterofDOOM wrote:ONE QUART PER 750 MILES?! That makes "batsh@t" seem like a personally reasonable state of mind. At that rate, to last the whole 5,000 mile OCI, you'd need to add SIX AND A HALF QUARTS. THAT IS MORE THAN THE ENGINE'S TOTAL CAPACITY. At that point, why ever change the oil? Just keep pouring quart after quart into the POS and change the filter on occasion.
The QR25 is the biggest turd to slop down the sides of the automotive toilet bowl since the 1983 Hyundai Excel.
That's why they call it "work", son.Chris.m wrote:checking those items takes time and gets you dirty.
