Stvo »
https://forums.nicoclub.com/stvo-u136912.html
Thu Dec 17, 2009 6:18 pm
Finally finished my recent projects (and it was a bit chilly down here in TX on Wednesday at 4am).
Upper linksThird links (no kingpin)Lower control armsTension rod bushings (VIN lists non-active - actual rods/bushings are for active)Front stabilizer (anti sway bar) rubberFront stabilizer (anti sway bar) connecting rod and rubberPower steering gear housing rubberMotor mountsOil pan gasket (kicking myself now for not looking for a magnet, although there was nothing mentioned in the FSM)Oil strainer o-ring (thanks for the advice on that one. the original was brittle and flat)
When I first started her up (after 3 weeks of sitting), there was quite the knocking and I was thinking it wasn't getting oil into the lifters (?), but after some time, she quieted down.
I replace the transmission mounts several months ago and hoped the new motor mounts and tension rods would make this thing drive 'like butter', as I've heard these cars can do. I didn't notice much difference, if any, and still have a bit of vibration....although I'm taking it in for another alignment (when I return from vacation) after all of this recent work.
2 vibrations - 1st vibration is minor and is felt during regular driving (any momentum, not idle). There may be some sweet spots, but I haven't recorded them. 2nd vibration is during hard braking. I rebuilt the rear calipers a few months ago and had the front disks cut (rears were too thin), but no change. Next will be the front caliper rebuild.
I also have a knock sensor error, which may be a culprit? Also heard that the driveshaft could cause vibration?...maybe wheel bearings? More reading ahead when I return.
Heard a slight/quiet knock possibly from the right side, mainly when I turn or hit a bump. Thinking something may be loose (rrrghh!) - will have to investigate further or mention it when they do the alignment.
Stabilizer rubber
Stabilizer Connecting Rods and Rubber
Upper Links
Third Links and Tension Rodshttp://forums.nicoclub.com/zer...49416
Lower Control Arms
Motor Mounts
Oil Pan
