Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.html
Sun Dec 16, 2007 7:51 pm
When you inflated the tires, it reset the TPMS system. You should deflate your tires to the factory suggested setting (34 psi?)
If the system comes on again, pay attention to it.
If it flashes for one minute when you start the car, then stays on solid, you have a SYSTEM FAILURE. You will need to take it in for service. System failures occur usually when a wheel sensor has failed, but in earlier Versas it also means the BCM is screwed up.
If it comes on solid while you are driving, it is reading a pressure drop or low pressure. If you check the tires and they're fine, then you have a bad sensor.
