Recap on e -> obd2de (for 88-89 ka24e's)
tagbok
Car: 89 fb soon 2 be 89rps13.5!
Doing an ka24e to obd2 ka24de (96+) in and 89.
After seaching everying, here zilvia.net club240.com. This is what i put together. Someone correct me if im wrong!
What it breaks down to is that i just use the block and head, get s13 duel cam harness, ecu, intake manifold and exhaust manifold and mafs. Do the same wire adjustments as if doing an obd1 swap (91-93)
And of course swap the ps pump and lines to duel.
(is there a difference between starters and ps pumps just out of curiosity, between the e and the de (96+)
anyone know the part or code # for the mafs and ecu for 91-93 5speed?
COOL article on ps swap, really simple.zerothread?id=99054
navysnail
if you do that, you will have about an 11:1 compression ratio IIRC, not a bad thing but you will have to use premium only. also, you have to swap all the timing chain stuff and maby a few other things. i think i remember someone on here acually doing that, ill see if i can find the thread...
