jhong1226 wrote:Are they going to replace the whole strut? or just part of it?
Second, Nissan will issue a second owner notification once the remedy is fully
developed advising all owners of the subject vehicles to have their vehicles inspected and
remedied. The dealers will inspect the strut housing and if no or only slight surface corrosion
is present, an anti-corrosion sealant will be applied. If moderate corrosion is present, resin
patches will be applied in addition to the sealant. If there is evidence of more significant
corrosion, a metal reinforcement plate will be used to reinforce the strut housing assembly.
In addition to the campaign remedy, and in the interest of customer satisfaction, owners of
similar vehicles that are not subject to this recall because they were originally sold in and are registered in states where corrosion causing this issue is unlikely to occur will receive a
courtesy notification. For those customers wishing to have their vehicles inspected, the strut housing will be inspected and repaired, if necessary, in the same manner as described above.
