IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Thu Jul 22, 2004 5:29 pm
i doubt it will come close to solving any of your problems since those components have absolutely nothing to do with your symptoms.
you need to open the fuel tank, and inspect the components. if you think that those parts will help you, this is out of your scope.
you most likely damaged the fuel tank, or the pump/sender bracket.
if the gauge isnt working, right, you probably damaged/dislodged the tank's gauge sender. in doing that, when you ran over the debris, you may have distorted the bottom of the fuel tank. that might be leading the fuel pump's pickup to become obstructed or uncovered when you make a hard turn. that in turn is causing the motor to bog when it no longer receives fuel pressure.
in other words, the fuel pump bracket or the fuel tank are damaged.
