dc1984 »
https://forums.nicoclub.com/dc1984-u34446.html
Tue Mar 24, 2009 8:05 am
since u say it is still stock t25, that means it is internally waistgated, so when u say, hks wastgate, im going to assume u r talking about the hks wastage actuator. never realy used one so not sure how the adjustments work on therewouldnt imagine it but i guess that might be a slight possibility.
do u have a boost gauge so u can moniter ur boost to see what its doing?
what do have the actuator hooked up to, what is ur boost source?it should be hooked up to just a boost source, no T's(unless boost controller) in the line and it shouldnt be hooked up to anything that has vacum. that means that if u have it hooked up to something off of the manifold, one of those three or four boost/vacum sources coming off of ther, then u r wrong. and from what i have heard, that can ruin ur wastegate actuator. which might possible cause a problem with it.but usually when an actuator is inop, ur problems would either be that u cant build up any boost, or that ur car just wont stop boosting.
maybe that is the problem, u hooked it up to vacum, ruined the actuator, now it wont open the wastegate and u are overboosting and u dont have a gauge to show it. just a thought. but, thats probly just some crazy theory i made up due to lack of info on ur particicular situation.
then again, maybe u just need a turbo rebuild. have u checked it for any shaft play? check for side to side, and in and out.
get back to us on this
good luck
