480sx »
https://forums.nicoclub.com/480sx-u50548.html
Wed Mar 11, 2009 7:14 pm
If you had operational tensioners both top and bottom, and oil pressure, there is no physical way that it can jump timing(ignore AMS's drag 240[Shimmed oil pump ftl and an over rev on that one IMO]) if the chain and guides stay intact. Even if the bottom guide breaks, its still not gona jump just make a bad noise.
The only way this happened is that you had your cam timing off a tooth from the start. This was most likely caused by one of two situations, unless you did something just outright wrong like.. Idk didnt have TDC set or didnt line the dots up.
A - When you lined up the dot on the crank sprocket then put the lower cover on + the middle sprocket, you let it move a tooth. This happened to me but i realized it moved when it happened and just had to pull the cover again. Its not hard to make this mistake.
B - When you installed the idler sprocket, then the upper timing gear, you let the bottom of the top chain skip a tooth. This is less likely simply because you said you had it set right to begin with, and im assuming that you know what a Ka's cams at TDC looks like, 10 and 2 right? At TDC, the intake and the exhaust cams sit at the same exact angle away from each other, upwards.
