Peabody »
https://forums.nicoclub.com/peabody-u10351.html
Mon Jun 01, 2009 8:26 pm
90 s13 (original owner)
Well I decided to buy a used factory ECU because my chipped one does not have any lights to check codes & we have no check engine light! I Installed the factory ECU & checked for codes. I am getting a Code 11 - Crank Angle Sensor.
When I got the car back from the shop 8 months ago that installed the new Jasper rebuilt engine I noticed that the distributor was turned all the way clockwise & it looked to be in a different position then normal. I checked the timing and it was at 18, I know the 24e is 15 and the DE is 20 & I always ran it bumped up a few degrees so I did not worry about it until now that I checked codes.
I am old school (own a 67 GTO) & drove a 73 GP-455 before I bought my 240 in 1990 so I do not really know that much about Fuel injection, ETC.
If the Crank Angle Sensor is throwing a code could it just be that the distributor was installed in the wrong position making the distributor look to be in a to far advanced position even though it is at 17 degrees? Or is something really wrong & should I make the shop look into it?
Is it OK to run the way it is or will the Code 11 throw other things off? My millage on HWY is 28-30 at 70MPH but drops to 14-16 in the City driving normal & have to use premium with the chipped ECU.
Only mods I have is the ECU, Header, Air Intake, Magnaflow exhaust.
Why did I keep my KA Well I can always turbo it - after 19 years not buying a new car I deserve some fun!
THANKS FOR ANY HELP > > > >
