gthammers »
https://forums.nicoclub.com/gthammers-u19435.html
Fri Sep 22, 2006 12:56 pm
Post by: neverlift
how is your cam timing? By wont come off idle do you mean the engine wont rev when you press the gas? Did you hook your cable back up to the throttle body?
----------------------------------------------------------------------------- gthammersIntake, Strut Bar, Plug Wires
Online
20 postsSan Marcos TX8-31-2004 « Re: (neverlift) 9:54 PM 9/20/2006
Yeah neverlift,Throttle cable is hooked up. And yes, I mean it wont rev when pressing gas pedal.
I drove it into the shop (150 feet) with the spun rod bearing before this in-frame rebuild. It had been sitting for 1 - 1.5 years.
It did this on initial start-up, so I thought well maybe the gas is crap! I used the fuel pump to drain the old gas and dumped in 5 gallons of new gas (minus what tried to pour into my shoe, the new spout design had looked soooo promising too....). Anyhow, this was not the problem. It did run just slightly better. After new fuel, new fuel filter too.
Then I suspected the new Bosch+2 plugs (never needs gapping?? says the box) so I swapped to a new 1mm gapped set of Champion Copper plugs. Same crap!!
I am about to discon the TPS and check the timing ($70 timing light), then recon as recommended in the info on the 240 bible post stuff.
When you say cam timing, do you mean cam/cam relationship or cams to crank? I think both are good or I wouldn't have buttoned everything up.
*_*_*_*_*_*_*_*_*_*_**_*_*_*_*_*_*_*_**_*_*_*_*_*
Maybe a bypass hose is pinched and not letting the extra fuel at idle return??
Maybe I have a crazy vacuum leak somewhere??
How do the internal butterflies actuate in the manifold?? Could this be jammed or missing an actuator rod?? This acts as a choke, right??
Could the TPS be screwed??
Thanks,Greg
Online
20 postsSan Marcos TX8-31-2004 « Re: 1991 240sx Rebuilt KA24DE will not come off idle, runs very rich (gthammers) 12:06 AM 9/21/2006
UPDATE ** ** ** UPDATE
Got it started, running poorly at about 570-670 rpm at idle -- no pedal. I got it to rev a little to about 1200 - 1400 rpm. Still not good combustion smell or sound.
It died and I got it restarted and kept it running with full pedal at about 800 - 850 rpm. I ran it like this while I tried to take the timing. I set the light to +20 degrees (stock for the motor) and got no good readings. I varied the setting on the light up and down and still saw no good reading.
After runing like this for 6 -8 minutes the temp started to climb pretty quickly. The revs went up and it started to sound better (still full throttle position).
Then the hose on the back of the thermostat housing blew off. The temp was only about 2/3 up. That is just a little over std op temp.
Obviously, I shut it down immediately!
BTW: Oil pressure light geos off after cranking or running, so I'm pretty sure its getting lube.
The intake manifold is maybe getting warmer than I might expect from just thermal conduction. Do you think I may be seeing some reverse flow (port reversion?)
