komete wrote:I do believe there is a short or maybe a relay is blown. I know it's not the battery. When there is a drainage problems and you turn the ignition to on the dash clock will go out but it stays on. Also the emergency lights and dome light stay on. There is no drop in voltage. Something between the Headlights, ecu, and ignition is toast. I've checked every fuse and visually every one looks good.
Sumation:no power to Headlights no power to ECUno power to ignition
time to go buy a bunch of fuses.......they are mad cheap anyway and always good to have a back up. replacing all of them and you remove that from the equation. just because visually it looks good.... doesnt mean it isnt the issue.
also a blown fuse for your turning HLs will not stop the car from starting.
time to check your relays.........
I still feel that there is an issue with something grounding out.
just for sake of taking the battery out of the equation, barrow someone with a good battery and test it.
it isnt a problem with your ignition switch as the HLs will work w/ or w/o the car on.
