Rebuilt Front CV Axle - is anyone making these?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
stops
Car: 2008 335i Coupe
1986 Z31 turbo swap
Hi all,
Does anyone know of a company selling remanufactured axle assemblies for the G35 - I have a 2006 G35X Sedan, Auto. I need the front passenger/right assembly. None of my parts searches online turned this up. I've tried 3 different garages who can't locate the part either (aside for the OEM part, which cost over $500.-$700) Buying rebuilt axles used to be a very easy thing to do, so I'm a bit perplexed here. Thanks for any help.
audtatious
Yeah, I don't know of anyone selling reman axles. Try and find a wrecked G that is being parted out or bite the bullet and get a new one.
munkle
Car: 2006 G35X
Digging through old posts here, but I ordered my front right shaft from http://www.infinitipartscenter.net/part ... XLE%20ASSY for about $519.00, including the shipping, and had it in 2 business days.
munkle
Car: 2006 G35X
And, I have a loose full axle assembly ready to be remanned and put back to good use.
stops
1986 Z31 turbo swap
thanks, but i just installed the new assembly this past weekend. Found a rebuild for $50 +$50 core on ebay.
audtatious
Good deal, hopefully the problem is resolved?
stops
1986 Z31 turbo swap
Heh - Not exactly. I thought the clicking was coming from the inner joint, but it's coming from within the carrier. So under 3mph or so there is still a click. No noise at other times. New axle works great though...
munkle
Car: 2006 G35X
When you removed your axle, did it have a clip on the end where it inserted and locked into the front differential? My old front right axle came out and did not have a clip on it, and the OEM axle I installed did not come with a clip.
stops
1986 Z31 turbo swap
Same exact scenario as you, Munkle. Though, I don't see any clip in the parts diagrams either.
munkle
Car: 2006 G35X
Yep, thanks stops. I did talk to an Infinitit "master tech" who told me how to put the axle back into the diff once the clip was installed - told me the trick was to rotate back and forth the opposite axle's tire while pushing the new clipped axle in.
Who knows, he could've been BSing me just for fun!
And you're definitely correct about the FSM and diagrams not showing a clip - I nearly went blind reading the front and rear axles' sections all the way through looking for any mention of a circlip for the diff-end shaft.
dunnmh
Car: Infiniti G35x (04)
hey munkle - u still got that axle & looking to get rid of it? I am looking to do this on my 04 infiniti g35x (front right), but i'd rather re-build it while the car isnt down... Let me know if you do!!
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
