WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sat Apr 18, 2009 8:19 am
Tons of assembly lube should have been used. If so, then do what 480 said. Turn it over with no fuel for 5-6 seconds at a time. Do that 3-4 times and you'll have oil everywhere it needs to be.
Then add fuel, restart and immediately look for oil pressure...right Nate
After you see that you have oil pressure, inspect for leaks etc. I idle for 15 minutes at a time.
For break in I subscribe to the "drive it like you stole it" method with lots of high vacuum decel and no lugging. Use regular oil to...the cheap stuff. Since you'll be changing it a few times and it promotes ring wear better. You might wanna look into actual break in additives. I've been hearing some stuff about these lately that seemed to make sense. Was on Hot Rod tv or something...
