rebuilt... another rebuild.
nisssan-drive
Car: 1993 240sx
So I payed this guy 1900 dallors to rebuild my engine( ka24de) and 800 miles later its ****ed up again. Turns out my crank shaft is broken, I wasn't sweatin it though because he said that it has a 1 year warranty. All though when I take it in he tells me 2 weeks later that if I want it fixed its going to cost me because he didn't work on the bottom end.
This is what he had too work on when it broke down in the first place. I think it was the pistons in 2 and 4 that were cracked, also the rod in cylinder 2 was bent. So is this true that he didn't even have too touch the crank shaft, and if it isn't should he still have too rebuild my engine any ways?
nismoracingsx
Car: 1993 White 240sx Coupe
if he had pistons and rods serviced/replaced, he would have had to drop the crank out. And should have checked the crank journals, bearings, and deck, etc, while he had it out.
low91240sx
Car: 1991 Nissan 240SX LE/2005 Nissan Altima
nismoracingsx wrote:if he had pistons and rods serviced/replaced, he would have had to drop the crank out. And should have checked the crank journals, bearings, and deck, etc, while he had it out.
Dead on he just doesn't want to replace parts and do labor for free I mean let's face it no one really wants to but I would be sticking it to him he HAD to of dealt with the crank no question about it what so ever he's just trying to take advantage of you not knowing that much about the bottom end of the motor he's full of get him man people like this make me wanna
nisssan-drive
Car: 1993 240sx
All right thank you guys man really appreciate the help.
