Hi, been lil bit since my long ago post. we solved the continued run on problem and bad idle with another idle hose to passenger side for idle control valve. all the at that point i hadnt had car warmed up all the way and full water circulation throwing off the temp sensor/causing poss fast idle richness. so now car runs smooth at idle, and more responsive. and plugs had white tips(changed to bosch irridiums from ngk, but now got ngk iridiums to possibly try).
i got conzult working on it(came with car i was lil clueless for sec) left o2 seemed dead so we replaced it. and it fluctuates faster then the right side(old one). so gonna change that right one out and also put in the wideband on adjacent pipe.
so now the car drives fine while not boosting, then if you boost it starts popping/cutting out a 0psi, then after shift the car stalls which is most likely due to blow off valves on maf system, and we got code 14 vehicle speed sensor?
also checked fuel pressure and it bout 38 idle and if you rev it the psi jumps to 50 and the back to 38.
(timing light 15 degrees btc, new tps set .45 and goes to 3.96 same as the old one werd)
boost leak test pending: found one positive boost leak on a bov conn, and some on low presure side but still seems to drop relly slowly from 2psi to one over like 15 sec. when i tried to pust 5 psi in system i hit my bro with the cottage cheese cup we stuffed in on side
so any more possibilities on stalling or the cutting out when trying to boost would be apreciated.
thanks.
