Eddie »
https://forums.nicoclub.com/eddie-u12286.html
Thu Nov 10, 2005 6:38 pm
The threaded hole where the brake line goes into the caliper is where you will apply the compressed to eject the pistons. When I did mine only one would eject completely out of it's cylinder at a time. Do use a piece of wood to stop the pistons.
When I did mine I could not find a fitting that would fit the threaded hole. I got an eraser and cut out a cicular piece to fit the hole in the caliper. I made a small hole in the eraser and then used one of those needles to air up a ball with to insert in the hole. It's kind of ghetto, but it worked.
