fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Fri Jun 18, 2004 9:27 am
when you have your pistons installed, you will need to have a machine shop bore+hone the block first (among other things).. usually the next step in the build process is to have the whole rotating assembly (that includes pistons/rod/crank/flywheel/clutch) all balanced together. This is a BIG DEAL when getting an engine to run right, especially a high peformance, high reving engine like ours.
As for cryotreating, I dont know all that much about it except that I heard it does do some good. I would talk with your trusted machinist when you bring your block down to be bored.
