Rebuilding
240sxHitman
Car: Boosted '91 240sx
I was just told my my mechanic that i will have to probably rebuld the my 91 ka motor cuz of crank problems, would i be able to just a turbo and manifold and the nessicary parts to go boost? do i need need forged pistons to complete it?and the its getting installed by my mechanic not a regular to turbo so i might have to get it dropped in then take it to some one who has dealt with KA-T's
and yes i know i have the future of an SR in my sig but i figured if i am getting a rebuilt motor why not add a turbo.
Structure240sx
get it rebuilt first. make sure everything is running good. this beats the sr now that you have a zero mile motor and sr's have at least 40k.
you are only a couple hours from me if you need a turbo kit installed
240sxHitman
well im motor which is gonna be rebuilt already will be here soon. im going to make sure everything is ok, then i want to look more into boosting it.
Couple of ?uestions. with the engine already rebuilt1. could i just bolt a turbo and etc on?2. As for the ECU what needs to be done?3. what about internals, besides pistons,injectors, what else is really needed?
WDRacing
Unless you want to do the tuning yourself, buy a JWT ECU, they are just under $600. The internals will be fine up to 350 or so whp. So if your planning on running big boost, you might as well change the pistons and rings. If not, then the sock internals are fine.
Structure240sx
what are your goals? then it will be easier to answer your questions
240sxHitman
Structure240sx wrote:what are your goals? then it will be easier to answer your questions
my goal is between 220-250whp which will be fine with me.
npaulseth
Car: 89 240sx
What do you mean "crank problems"? If you have damage to your crank, I would sugest buying a new shortblock or a good condition used crank. "Rebuilt" or resurfaced cranks make me nervous.
240sxHitman
npaulseth wrote:What do you mean "crank problems"? If you have damage to your crank, I would sugest buying a new shortblock or a good condition used crank. "Rebuilt" or resurfaced cranks make me nervous.
yea something is loose and theres a continous knocking while drivingits a different motor thats gonna be rebuilt
