Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Oct 01, 2008 8:52 am
He's building an SR. This would be the place to ask. I wouldn't expect the Z guys to know much about an SR.
Since you're looking to hit the upper 300s (which in a Z is more than plenty), I would recommend building the motor first. 400 is the average power rating an SR can put the wheels before things begin to break. And I mean average, as I've seen blocks go above that, and blow apart below it. It's all in the fuel management.
To me, it's a little cart leading the horse if you're planning on building the block for power longevity by making it lay down the power first. However, with a good tune, you can make a stock block SR hold that amount of power. One thing to remember is you're using a junkyard motor. You're taking a gamble if you try to slap a turbo on it and push some big numbers without doing some prep work first.
One of my friends has a built up 280z. Bored the L28 out. I think it's rated asa 3.0L now, not sure. And he has a turbonetics ball bearing turbo on it. It only puts down a little over 350, but in that car, it absolutely roasts tires, and is a blast to drive.
