180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Sep 01, 2005 7:23 am
Depends on the budget. If you're a strapped for cash college student like me, ie just makin it, then a port and polish might be out of the question since a good one can cost quite a bit. Don't go cheap on that service, since it can make your motor run like real trash if not shaped right for your specific application.
Cams won't really do too much for your motor if everything else is still stock. If you've got busted valve seals, then I'd probably go ahead and do the rest of the job like springs and retainers, but otherwise, I'd probably keep them stock until something else rolls around that'd justify such a cost with such minimal gains, like a turbo.
So it comes down to your mods, and whether or not you'd be willing to cough up a pretty substantial amount (enough to buy books for at least a quarter/semester) for pretty minimal gains especially if you're planning to rebuild the bottom end later on (you should be able to talk to your machinist to get something discounted if they're rebuilding an entire motor with a p&p). Just my opinion though, it really depends on what you want to do with your cash.
