Rebuilding my motor, broken piston ring?
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
Pulled the piston out and found the ring was broken, luckly the cylinder walls were left unscaved, but what would cause something like that?
boost_boy
XTCshri2222 wrote:Pulled the piston out and found the ring was broken, luckly the cylinder walls were left unscaved, but what would cause something like that?
Pay close attention to the piston. I don't think you broke a ring, but a piston instead. And that is caused by detonation or overly advanced timing, too much boost and not enough of a supporting engine managememt system to support the boost you're running.
Dee
float_6969
As Dee said, it's probabally caused by detonation, the cause of the detonation can vary widely, but is genrally caused by too much advance, not enough fuel, or excessive intake air temperature.
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
+1 here, they normally break when the piston compress of high cylinder pressure (detonations).
/Mike
boost_boy
Dude, I got to post some photos of some busted pistons of mine from the previous 7 years:
The one on the left is a wiseco piston. It doesn't matter what piston you go out and buy, if your pushing your system past it's limit, BLAAAAAM!
Dee
XTCshri2222
i've kept the boost down, and been running rich, babied it. was pretty advanced for a while be fixed it to 15degrees. i do have fuel managment on there, but since tearing open the motor looks like the previous owner beat on this thing, there signs of flooted valves on the cams and lifters.
XTCshri2222
boost_boy wrote:Dude, I got to post some photos of some busted pistons of mine from the previous 7 years:
Dee
outch thats painfull
float_6969
Still not as good as the piston that I pulled out of my 2.4L in my old Ford Tempo. The engine caught fire and I melted the #4 piston IN HALF. ( I mean that in every sense of the term)
boost_boy
float_6969 wrote:Still not as good as the piston that I pulled out of my 2.4L in my old Ford Tempo. The engine caught fire and I melted the #4 piston IN HALF. ( I mean that in every sense of the term)
Yeah, well I got a GA16i that came out of a car I purchased and that thing tore two rods from the crankshaft, through the block, and then wedge itself between the downpipe and the cross member and the car was stock/auto. Don't talk about the piston (piston what?)
Dee
