blue_hauder »
https://forums.nicoclub.com/blue-hauder-u3599.html
Fri Jul 04, 2003 5:34 am
How was your timing chain cover. I went throught this with my old engine. The car overheated one day when I was driving it and I found antifreeze in the oil. I thought that maybe the head gasket went out so ended up taking the cylinder head off and replacing the head gasket and putting it all together to find out that I didn't fix anything, same problem. Well after that I thought that the block was cracked and bought a new engine for it. Well when the old one was out I took the timing chain cover off and discovered the chain ate throught the cover.
