Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Fri Oct 11, 2002 2:21 pm
pistons and rings should be dedicated turbo stuff since the NA motor uses 9.5-1 and isn't supose to see the kind of operating pressure that the turbo puts the motor under.
The headgasket works just fine, same with all the bearings, oilpump, waterpump, main bolts, rod bolts, headbolts, it's all the same. The NA also uses the turbo crank and rods.
The intake and exhaust manifold gaskets are also the same, so you can interchange them when you rebuild.
The NA timing belt also works.....
only thing that dosn't come off the NA motor is the O2 sensor, that's off the CA18ET powered 200sx (s12).
PaulOrlando, FL
