S14KoukiMonster »
https://forums.nicoclub.com/s14koukimonster-u36640.html
Wed Feb 01, 2006 10:46 am
It definately wouldn't hurt to regrind valves and valve seats. Good idea to adjust valves w/shims for valve lash, replace piston rings,crank+rod bearings, get a metal head gasket,ect. If I were rebuilding an engine, I'd take it completely apart to see EXACLY what I'm working with, so that way I know what parts are still good, and what parts I need to buy. Then I'd evaluate the condition of my block and head, to see if the cyls need machining/honing, or block decked ect. I work on cars all day long mind you so I'd strip/build it myself. The only labour I'd pay would be to a machine shop.
Stipping the engine all the way down to at least evaluate is definately the best way. More expensive right now, yes. But going cheap now could cost you ALOT more down the road. I assume you'd like a new engine with years of reliable usage, not one you have weak points in.
