DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Aug 01, 2005 9:05 am
That is pretty much the case for all journal bearing caps. When manufactured, the caps are bolted on tight and then they drill a nice very precision hole down the center through all bearings for the cam to sit in. There is about .002" of clearance between the camshaft and the bearing caps at all locations, which is about 1/2 the thickness of a sheet of paper. (If there was no clearance, the cam wouldn't turn, and if the clearance is too big, the oil pressure would drop too low.) But when they drill the holes in the caps for the bolts, they're put in much looser, maybe to within a tolerance of .005 or .010". But it's OK since they're drilled first, before the camshaft hole is drilled. But once everything's done, it's locked in. There's no swapping caps because each cap uniquely matches the profile of the other 1/2 bearing at it's location. A machine shop could probably open everything up and put in graded journals, but I think this would cost more than finding another pair of used heads.
