Jeff Williams wrote:Did it ruin the crank?
Can those caps be cut and re-ground, or do you have to get oversized bearings?
Keep the photos coming! If you ahve a macro setting or close-up setting on the camer, it will help with those up-close shots.
The crank is of by 0.10, that means it has to be grinded (is that the correct word?) and i need a 0.25 oversize bearing. The rest just need a poliching and it will be fine.
It's not my cam, and the owner told me there was only auto settings.. (It's a 100$ cam)'
Sorry about the bad English...
