rebuilding calipers
eddiec
Car: 91 S13
i have some z32 caipers that i want to rebuild w/ fresh seals.
i used compressed air to try and get the pistons out, but only one side will pop out. how do i get the other side to come ouT?
wild_maxx
Car: 90 TT pearl yellow z32
you have to plug the fluid passage hole thats inside the piston hole. If you look inside there you'll see a small hole... since one of the pistons is out already your just blowing the air out of the hole that was plugged up by the first piston.
I used my finger to plug the hole while i gave it a little air pressure... the second piston came about half way out then I just pulled it out by hand. (BE VERY CAREFUL WHEN DOING THIS!!!)
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if you hold the old pads in the middle you can use the compressed air to push all 4 part way out then you can pull themm individually by hand, although too late for this now
eddiec
Car: 91 S13
ok so i got around to working on these. the pistons came out pretty easily by simply rockin them back and forth w/2 screwdrivers. and the mounting bolts were the perfect size to gain extra leverage with.
