superuber wrote:OK, so can joe get me brembo calipers like the pics?Lino, post a link,please! (gotta get rid of some money)
Don't get me started Rick....
2005 Maybach Exelero
2003 Maybach 62
2006 Brabus S V12 Biturbo BRABUS high-performance brake system with 12-piston aluminum fixed calipers and 380 x 36-mm vented and cross-drilled discs in front, and 355 x 28-mm discs and six-piston aluminum fixed calipers on the rear axle.
Bugatti Veyron 16.4Unique cross-drilled and turbine vented carbon rotors draw in cooling air. Each caliper has eight titanium pistons. Bugatti claims maximum deceleration of 1.3 g on road tires. Prototypes have been subjected to repeated 1.0 g braking from 194 to 50 mph without fade. With the car's fearsome acceleration from 50 to 194 mph, that test can be performed every 22 seconds.
Brembo GTR High Performance Braking Systemhttp://www.rogueengineering.co...ode=B
ScienceofSpeed Brembo Indy Brake System
http://scienceofspeed.com/prod..._Indy/
Brembo offers their "Lotus" caliper as an off-the-shelf kit. Brembo has many different GT caliper sizes - "Lotus", "F40", "F50" (Same caliper size but larger pistons than F40), all of which are 2-pc calipers, and their new 6-piston monoblock caliper -which was called "enzo"
Brembo Enzo brake kit, 410mm rotor.
Brembo Lotus
Brembo F40/50 (50 pictured)
Brembo 6-piston monoblock
http://www.pim.net/brembo.htm
http://www.pelicanparts.com/bm...e.htm
