neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Sun Dec 20, 2009 3:49 am
well you can break stuff taking it apart, but unlikely. You can really f*** the diaphragm(s) up on assembly, by over tightening.
chances are this is a 12:1 and the lower aluminum disc is shot(just like mine :p )its okay if the diaphragm is still good , you can make another one from a mtn dew can but it has to be mtn dew or it wont work. I could not justify the 50 bux vortech wanted for a small aluminum disc and silicone diaphragm. If the top is already 8:1 you should be good once the visual inspection is done. But if you have to buy the recall kit go ahead and get the tuning kit for a few bux more. best prices I found I think was superchargers online, fast cheap shipping
can I also advise you to spend a few hundy more for safety items? such as wideband a/f monitor,walbro hp pump,and 300zx filter, and if any fuel lines are suspected to be under rated swap them to something better goodyear makes decent rubber lines that have a sleeve in them, making them very strong.good luck man pull 3* if you live in warm weather or get s***ty 91octane , keep it under 8psi and long live the kat
