Rage_sixtynine »
https://forums.nicoclub.com/rage-sixtynine-u8742.html
Sat Oct 07, 2006 10:12 am
For those guys that have rebuild the GtiR t28,I've got another question, reading instructions and looking at pictures and also looking at the parts in my kit, they all point to me having another snap ring on the outside of the exhaust side journal bearing. However when I disassembled the turbo, there was not a snapring, but a spiral ring on top of a washer. If I put this turbo back together as it was taken apart, then what will be in the 2nd groove on the turbine shaft? one of the grooves will have the piston ring, and according to pictures, there should be the spiral ring in the 2nd groove. But, i've already used the spiral ring to hold the bearing in. When I removed the shaft originally, there was nothing but carbon deposits in the 2nd groove. I just want to verify that this is correct, I dont want my turbo going boom right after I install it. Please guys, if you could help me out. Thanks.-Trent
