rebuilding a r200v differential
nis300zx
Car: 1990 300zx n/a
How hard is it to rebuild a r200v differential? I have been been hearing horror stories and to have a professional do it.
s13sr20chris
never done a r200 but i have had them apart before. it does not look hard to me as long as you have all the precision tools(i do).
hamsterball
Car: 1990 White Nissan 240SX Fastback
It's not that hard.. just takes time.
You just need a vice, and a biiig socket for a few bolts... I took a look at my VLSD when I was replacing the rear cover gasket.. and was contemplating on whether to replace the races, bearings, and oil seals..
but if i had the right tools, i bet it wouldn't have been impossible.
180fan
Car: 89 fastback
If you are not able to check the tolerances and clearances you can and will shorten the life of your diff. Just FYI.
s13sr20chris
180fan wrote:If you are not able to check the tolerances and clearances you can and will shorten the life of your diff. Just FYI.
bingo! dial indicator set is a must.
