samuraijesuss13 »
https://forums.nicoclub.com/samuraijesuss13-u104092.html
Tue Sep 09, 2008 8:00 pm
well i was looking thru the KA-T.org forums and found this
Average: 300 rwhp to 350 rwhp, you have to start to expect a little more lag. This is about the perfect "street car" limit. No race gas, just good honest street car fun that is fully capable of bring home a 12 second timeslip on a good run.
Turbo Manifold T3/T04E .50 Trim compressor, .60 trim compressor housing / Stg 3 (aka TA31) turbine wheel, .48 to .63 A/R exhaust housing. Internal wastegate optional but not recommended. Downpipe can still be 2.5", but this is as far as I would want to push that. Front Mount Intercooler (FMIC) It's time to upgrade to a larger front mount as the larger will push more air than the smaller sidemount can cool.
Fuel Control 550cc Injectors SAFC2 to control your fuel injectors, along with the stock ecu. MSD BTM At this stage I would be running the BTM to control timing retard. Reflashed ECU-This can be a DIY thing with Megasquirt Tuning or a JWT. Z32 Maf is required, as the stock Maf stops being able to read at around 260 rwhp. Wideband O2 Sensor should be installed for tuning.
Block Internals This is where I would start to consider it necessary to replace you pistons.
is that a pretty good example to follow and maybe go a lil further with maybe a full 3inch downpipe and exhuast and stuff like that?
