Rebuild Time....
fabio240
Car: S13 with ca18det
Ok so Last nite I spun a rod bearing doing a burnout (completely my fault) but anyways I want some input on what bearings in the bottom end I should go with I will be using stock rods and pistons Im just curious as to what material type, bearings sizes, and what companies are good. I do plan on revving the motor to a 8.5k with a 50 trim t3 and some headwork. And also I will not be using my block I will be using another CA18DET block without a spun rod bearing.
Ca_Silvia
There are tons of rebuild threads, it is the CA18DET forum. Anyways if your technically doing a stock rebuild you can't go wrong with Nissan, or step up to some better parts. Your call.
FR Sport carries just about everything we need for a rebuild. Stock or performance rebuild.
