95si4 wrote:what do you estimate the increase in stroke would be?
How wide is the crank case?
Seriously though, if a shop knows what it's doing with welding and grinding, the only real limit is harmonics and the physical space that the crank has. I know on L series straight sixes, that a 85mm weld/grind isn't *uncommon* as these things go (which is 6mm more stroke than stock), and I know of atleast one person in the US recently (in the past few years) built a 89mm crank (10mm over stock [stock is 79mm]). I know that in Japan in the 70s they could get up to 3.5 liters out of these engines (which at max overbore equates to almost 92mm in stroke).
So it comes down to how much you want to spend, and how much room you have to work with. I guess in theory if you went with smaller diameter rod journals you could push it even more....
