evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Feb 02, 2007 8:12 pm
no thats the kit for a Z31 trans, really unless you know what you're doing you're better off swapping in a known good trans, you're problems could be coming from a syncro or bearing or a work gear, you have to inspect all the aprts and replace what needs replacemet and any kit you might find is generally only snycro's and bearings, and I believe the bearings are pressed on so a bearing splitter and press would be needed
and the reverse issue pops up a lot of times with a work clutch but second gear sounds more like a syncro problem
