So I've been bad about keeping my peeps updated on my engine status. So here's a little history if you don't know it. I bought my CA as a font cut back around '05. I installed it shortly after with a FMIC, 3" turbo back, KA TB, Apex N1 single, and an Apex PowerFC w/550's. I beat the crap out of it for about a year until the piston rings started leaking so badly that it was burning so much oil that I couldn't drive it on the street anymore. So I pulled the motor and had it rebuilt with some custom CP pistons with 10:1 compression (I thought it was 9.5:1 at the time) and 83.5mm overbore. I also put new bearings in it, new oil pump, new water pump, polished combustion chambers, port matched intake manifold, polished head, an S15 SR BB T28, SSAC turbo mani, mid mount intercooler, oil cooler, and an SDS EM4F (standalone). This did me well until I realized that placing the air filter in the fender well for a CAI with out the plastic fender liner is a bad idea because the rocks from the tire punch holes in the air filter and then debris gets into the turbo and mess up the compressor impeller. So I swapped in the stock CA T25 because I had it laying around. I cranked that thing up to 15psi and ran it like that until somebody offered me more money than I could pass up for my S13 w/a KA-T. I then bought an S14 to swap the CA into. I ran it with the same setup as in the S13 (minus a LTA intercooler instead of the mid-mount) for a while until TMS (themadscientist) offered to sell me his HKS turbo kit, which I couldn't pass up. I had to remove the brake booster and redesign the braking system to get it to fit, but fit it did. Then I had an oil filter fail, and ruin the head and all of the bearings in the block
. So rebuild number two. This was supposed to be a simple rebuild, but since the head was ruined I had to put in my 4 port head I've had laying around forever. I port matched and polished it (including combustion chambers and the sub-manifold, and a valve job) and put it all together. It didn't run like it did before, but my intercooler setup wasn't what it should have been and I had also installed some HKS 264's and cam gears I'd had for a while so I wrote it off as that. I hadn't had a chance to tune it yet either, so I wasn't too worried about the poor performance. I should have known better. I discovered that the HKS 264's HAVE to be indexed (ie; use the cam gears to set the cam timing). I hadn't done this, so I pulled the spark plugs to set TDC so I could index the cams and discovered that the #4 spark plug was in BAD shape. The ground strap was melted and the porcelain was cracked and a piece was missing. I did a compression test and found that all 4 cylinders were low, but #4 was REALLY low. I could also see that there were some marks on the top of the piston. So I pulled the engine and tore it down. The company that built the engine (no longer in business...surprise, surprise) failed to the debur the second ring on the fourth cylinder. This caused the ring to badly score the cylinder. I'm guessing this caused the issue with the spark plug. So now I'm on engine rebuild #3. I also found out that the last machine shop had re-surfaced my flywheel, but they're not supposed to do that with a steel flywheel with a hardened surface PLUS they didn't step it properly and it's a JUN flywheel, so I have no way to find out what the step was supposed to be. I also found out the my SPEC Stage 3 clutch was finally near the end of it's life (it and the flywheel were installed when I first bought the motor, well over 50K HARD miles ago) Anyway, I'm using a different engine builder now(of course). This guy does the work himself (the last place just had guys working for him and it always seemed like it was a different guy every week) and seems to know is stuff. Current setup will be;
-Supertech pistons, 84.5mm, 8.5:1 compression (the overbore will yield 8.75:1 if I did my math correctly). They're not great compared to the CP's, but they won't be noisy when cold like the CP's were and won't wear the cylinders like the CP's did. (there was no crosshatch left on the cylinder with the CP's at 40k miles and compression had dropped from 215psi right after break in, to 195psi right before I tore it down after the oil filter failure).
-Supertech rings, but the 2nd ring has been modified by Total Seal to be a gapless ring. My plan is to help cut down on my CA's infamous amounts of copious blowby.
2013-10-16-1757.jpg by
nismoman240sx, on Flickr
2013-10-16-1758.jpg by
2013-10-16-1761.jpg by
2013-10-16-1759.jpg by
-King Bearings coated by Calico (as per my new machinist suggestion)
-Stock rods with ARP rod bolts (my machinist said that the big end of the rods were still perfectly round after the ARP rod bolts. You should still ALWAYS check the rods for roundness when you change the hardware, but many other ppl have had the same results as I had)
-SR ACT street/track steel flywheel
2013-10-16-1755.jpg by
-SR ACT 6 puck clutch with sprung hub.
2013-10-16-1756.jpg by
-Get to the dyno and tune it for current setup and see what this HKS turbo setup does at 25psi!
