I'm still deciding whether or not to do the JDM swap or rebuild. I would rather rebuild but the budget could get skinny real quick if I need professional help. I have done a few things with motors in the past (heads, timing kits, accessories, etc) but have not dealt with pistons, rods, cranks, etc. I REALLY would love to do this build myself to say that I accomplished it, and I have NO time restraints as this is a project car. Keep in mind, this did get water in the oil, so I'm prepared to get the heads resurfaced. I have not pulled the motor yet, so there is still the possibility of a cracked block which would shoot this down completely. So for arguments sake... lets say it needs the heads resurfaced and I'm buying the Z1 rebuild kit and going to have the turbos on the car rebuilt after inspection.... Is this feasible with support from forum postings with images or should I run for the hills? I'm anal about detail and I work on computers, so being organized enough to put stuff back where you found it is attainable. I'm sure there are a few things I would have to pay for (acid dipping, etc) but a JDM shipped with 60k timing kit, harness, ecu, and new oil pump would be $2k. And even though I would have it inspected and compression tested before purchasing.. something still feels uneasy.
