Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Wed Jan 23, 2008 3:34 pm
PLEASE READ THE WHOLE THING BEFORE YOU POST. I need as much accurate info as possible.
RB25DET S1
I have a few questions.
I know how to run a catch can, and all that jazz through the previous thread.
Earlier this week, i noticed a rough idle in the engine so i pressure tested the intercooler pipes. I found several leaks and fixed them, and i also noticed that the PCV valve was letting pressure into the valve covers and coming out my catch can lines.
So i removed the PCV hose, capped it off and blocked the valve cover off with a tight rubber fitting. While i was looking at all of this, i noticed a great amount of moisture built up into the hoses running from the covers to the tank. I've never seen much moisture period in the lines period untill recently.
I live in oklahoma and right now its cold as hell outside. The car is garaged at night so the coldest it see is above freezing during the night, but is exposed to it later in the morning after i go to work.
I pulled the top of the catch can off to find at least 3/8 of a cup of water in there just below the return line on the can to the intake.
There was also a milky white oil/goop mixture on the fittings and a few other places.
I cleaned it all out and it idled perfectly fine and stays solid at 800 rpms and drives fine under load.
I did a compressoin check tonight, now the FSM says at 300 rpms, the standard value is 12.5 bar which is around 175 psi, and the limit is 9.5 bar which is around 125 psi or so.
I have an RB20 starter and an RB20 9.5 lb flywheel on an RB25DET so it cranks notably faster than it did when it was stock with all the spark plugs out. Before and after the flywheel was installed, so i can imagine that its going a bit faster than 300 rpms but not by much if any, i dont know, but im sure that doesnt effect the compression reading much.
::edit::One thing i did not do, was release the fuel pressure, and open the throttle body completely::edit:: The engine was at operating temp when i did the test though. Cylinder 1 127Cylinder 2 127Cylinder 3 129Cylinder 4 129Cylinder 5 127Cylinder 6 130
With it running just the same as it always has, making around 272 rwhp on around 12 psi with an 11.3 afr, and 15 degrees of timing, i cant possibly see needing a rebuild, but i might also have a gauge that reads low. With the difference between all cylinders being pretty slim i think that it might be ok.
Now i understand that moisture collects in these things, im getting a different catch can, and running one that is baffled, and put the feed line in the bottom and the return line to the intake hose before the turbo.
Here are some pictures of the moisture.
There was also some moisture on the dipstick as well.
All i really want to know is if everything is normal, because im a paranoid S.O.B. when it comes to this engine.
