jeremy242 »
https://forums.nicoclub.com/jeremy242-u48821.html
Mon Dec 11, 2006 1:47 pm
Ok here is the situation, i have a sohc ka and i had the block bored and honed 40 over (it was recomended that it be done that much), block decked, crank polished, head job done, head decked, flywheel refinished. All machiningwas done at a very reputable shop.I got a full rebuild kit new oil pump, pistions, gaskets, everything.I assembled the block by what the chiltons manuel says for torque specs and everything, filling the oil pump, assembly lubed everything that needed it.
What i have done to the engine is that i have removed all of the egr stuff, put on an obx header, removed mechanical fan for elecrics, and disconected the butterflys on the intake, and installed and oil catch can.
the problemsa none constant idile( probably due to the butterflys)i get oil preasureat start up and then it goes low to no oil preasure, and it does not increase as the revs dothe headers glows with just 2000 rpmthe head ticks alot
The timing is set at 20 degrees and the engine has not been run for more that 3 minutes at a time and the revs have not gone passed 3000 rpm. I guess what i am asking is if any one has experienced this or has any suggestions on what to do.
