rebuild or not?
CFLmmaChamp
Car: 1990 240sx sr20swap
i have a 1990 240 with the rd20 swap i wanna push something like 270+ hp with her and as of now i need to buy new or rebuild it what would be the best way to approch this project? :gapteeth:
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
It depends on how much damage is done to the motor...if its minimal than I'd say rebuild
CFLmmaChamp
well it has a knock in it thats fair but other then that its clean. any ideas on the cost difference? im leaning more into just buying new.
compactfean
daily
Well lets say your crank needs work and you new rod. There is 300. Bearings and head gasket and oil pump another 2-300. So for 5-600 you would have a pretty sound motor again ....buy one used, for 6-800 and not know if its gonna last.but no down Time. Unless you don't know how to rebuild a motor than add the 1000 labor for a shop to do it.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
But it wont rebalance itself... I'd re ring, main bearings, rod bearing, crank polished, head gasket and timing belt at a minimum. I dunno I'd say closer to 1500 with the balance and polishing / clearance work.
CFLmmaChamp
well the price on a new one is not that bad so i might just start freash and go from there. thanks guys much help! any ideas on how to push 270 hp in a nice way?>?
compactfean
daily
What ever you do I'd make sure that the motor your getting wasn't shipped to the states. Recently ...lol.also I'd tear down the motor you have now and check to see if the crank is still good ...that alone will tell you how much its gonna run you. I just built my buddies motor that had a bad rod bearing and he is 2200 bucks into it and that's with race bearings forged pistons and eagle rods and that includes the crank he bought from me. As far as your horsepower goal, a t28 mild cams different maf, 50lbs inj and a chipped ec should do it.
CFLmmaChamp
great thanks much ill keep posted on progress :)
