es.biggs wrote:Do the turbos have to be removed to get the heads out of a TT?
I'm sure some crazy sonofoabitch has done it, but it's definitely not recommended to try it. You'd at least need to disconnect the water and oil lines.
Personally, I'd find a good condition used USDM motor, do a 60K/120K service on it and be done with it. For your budget, just engine, no upgrades, I think that would be the smartest money spent.
If the mechanic did their own compression test, post the numbers. Compression can be bad for many reasons; some only require a head pull (head gasket, bent valves), others require a rebuild of the bottom end (hole in piston, shot rings).
