rebuild kit
exodus5547097
name the parts to rebuild your 89-93 240sx motor. I know nothing about motors and cars. Please help
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
depends on to what extent you plan to rebuild, if the bores are not scarred and the compression is good, just a light hone with rings and bearings (rod and crank), followed with new seals and gaskets and a fresh oil pump, should do the trick, if the cylinder walls appear damaged or compression is low plan on new pistons and an overbore, youre best bet is to take the short block to a machine shop they can evaluate the condition of the block and order the needed parts while doing the machine work
