Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Feb 05, 2008 4:56 am
There isn't a "rebuild kit" so to speak for a motor. You need to call up your parts department and start ordering parts for the motor such as rod bearings, gaskets, main bearings, etc. Since he's complaining about a rough idle and some smoke, I'm tempted to say he's got a holed piston. I've seen quite a few SRs that would not die on idle, but have damaged pistons.
In a case like this, you really would need to let the motor dictate how the rebuild would go, which means you'd have to buy it, tear it down, figure out what's busted, and then formulate your rebuild path.
Personally speaking, while there are a few decent upgrades, the car doesn't seem worth the money. If it were about $500 cheaper and you were good at rebuilding motors, i would say go with your gut. Just be careful and don't go in over your head on this one.
