Touchdown038 wrote:Alright, I need to take a trip to the dealer tomorrow anyways so I'll add those on. I was also thinking about new nuts for the rod bolts too... necessary?
Not a bad idea
Touchdown038 wrote:Next question: I'm sure that when I took the rear main seal housing out, there was RTV on it. Well my gasket kit contains a seal for it. Should I toss it and use RTV?
This depends on what seal your talking about. There may or may not be a gasket between the engine block and the plate. It depends on the design or the main seal plate. I dont think the 240 has a pan lip seal as I think it rests flat against the pan. But if the pan has a half moon drop that allows the rear main retainer plate to sit in, then there is a rubber lip seal that goes there.
Touchdown038 wrote:Opposite thing for the EGR to mounting bracket. I could have sworn there was a gasket in there, but there isn't one in my gasket kit. Should I check at the dealer while I'm there?
on your egr it is a 2 peice deal. the egr base plat mounts to the intake manifold and has a geasket between it and the manifold. The egr mounts to the base plate there is also a gasket there.
