slc240sxse »
https://forums.nicoclub.com/slc240sxse-u17743.html
Tue May 17, 2005 3:16 pm
Well, the only dilemma that I am faced with at this time is to do a ton of research on the proper internals. As I mentioned before, I've had no problem rebuilding engines in the past for my Mopar projects. With those though, it has been fairly simple. I'm hoping that it will also be the case here. This will however be my first turbo project. About all I know is that I should have a lower compression ratio, such as 8:1, to run a higher boost level. As far as what cam, and pistons I should go with, I really have no clue. My last project was my 71' GTX 440 Six Pack. It was bored 60 over, with 10.5:1 pistons, a purple cam (longer duration) timing gears, as well as a complete rebuild of the 3 2 barrel carbs, each of which had about 250cfm if I'm not mistaken. That was easy enough to have done. I also had some great lifters tossed in the head.
Does anyone know of a great shop that I can buy all of the above items, or are there any specific hardware suggestions (brands) that I should go with? Will I need stronger rods to run more boost? I know that when I rebuilt my 440, I had stronger rods due to the six pack. That car dyno'd out at about 400hp with about 425+ torque NA.
Also, once I build up the engine, and all is done such as big injectors, a larger MAF, and what not, I hear that JWT can do custom ECU programming for these engines?
Thanks!
