deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Thu Apr 29, 2004 8:01 pm
You probably found a lot of smaller plastic shavings as well, this is what led to your bearing failure and is very common. Like corn322 said, those plastic bits are from a busted chain guide, same with the smaller plastic chips.
Anyway, as far as a rebuild, it all depends on how much you want to spend. Most likely your rods, and crank are all in rebuildable order. Stock rods like noted various times before are very stout and upgrading them is only necessary if you plan to push massive hp and you have a lot of cash.
If you plan to eventually go turbo, the 9.1:1 pistons are probably not the greatest option. They are higher compression for one, and they are no higher quality casting than regular. Pistons are the one thing that you will want to upgrade if you are planning on higher hp figure, na or turbo. So you will have to decide what you want to do. I sell standard oem-style ka pistons (as well as other nissan/toyota/mazda/mitsu/honda pistons/components) in .020", .030", and .040" overbore. The 2.5l high compression kit has been phased out, and a new version will be available soon.
As far as cam, assuming you run a ka24e, pdm is the best way to go. These are reasonably priced, and work very well. I have run a few of their cams and have nothing but good things to say. The c404h is great for na, and in turbo form should work well also.
