j-z »
https://forums.nicoclub.com/j-z-u11653.html
Wed Aug 09, 2006 6:57 am
so did you install a new front cover? if so check your old cover to see if that oring came off with it. i remember i got that oring in my felpro gasket set. sorry i dont have any pics, but if you dont have that gasket in place it will def cause no oil psi. its part metal, and part silicon. the metal part is lipped and sits inside the main oil port, and the silicon part seals between the block and cover. on my fresh motor i built, i got oil psi the first crank.
